BBSHD Fat Bike build, derailleur mounting plate bracket issue?
    Hello electricbike members,
    I'm planning my next build on my KS cycling Fat Bike 18 inch frame with BSA120 mm Bottom Bracket. I am planning to purchase the Bafang BBSHD 120mm (Extra Fat). The only thing what worries me is the front derailleur attached on a plate which is welded mounted underneath the bottom bracket. I'm not sure if the plate is touching the BBSHD after removing the original bottom bracket and installing the BBSHD. Hopefully i won't encounter chainstay issues after installing but this could be solved with spacers.
    Sure, it can be removed by grinding the plate of the bottom bracket but this is not ideal. Has anybody encountered this issue with this kind of frame and how did you solve it? Attached a few pics so you get the idea.
