It seems like it wouldn't be too tough to make my own programming cable. Luna is out of stock and I'd like something a little longer anyway.
Does anyone know the pin out of the connectors?
How to connect the Bafang BBS-02 and BBS-01 e-bike controllers to a laptop and program via USB to Serial TTL FTDI adapter. Using the Bafang configuration app...
I dunno - I think it's pretty easy... OTOH I work with these little USB/UART converters quite often and the worst part always seems to be getting RX and TX straight (if you just plain guess you will get them right <25% of the time and if you noodle it more like <10% of the time - thank you Mr. Murphy ;-} ) and the US drivers are way too often a big pain...
You can create you own cable but even the most experienced sat it's not worth it. Here's a link to a well regarded BBSxx blogger who in discussing the pros and cons of build versus buy provides links to how to build.
For information on the programming parameters and what they do you should check out The Hackers Guide to Programming the BBS02 located here. UPDATE: The BBSHD is programmed in the exact same way wi…
I bought one.... But I'd build one without hesitation if they were out-of-stock...
I've been using some very inexpensive (~$5?) ones that I've not needed drivers for (windows recognized them without any help). I'll check if I can find a link...
I bought a programmer last year but I'll be danged if I can't find it. I just finished another build and desperately wanted to load Karls el file so I resorted to this. I would not recommend it but it worked. I had some cheap speaker wire so I used a small safety pin and reamed out the cut off ends and slipped them over the male pins.
