There are so many questions I could ask about the cyclecone3000, that I had to do real thinking to eliminating the foolish ones (I hope).
I was wanting to mount the motor on the left side for a single speed drive. I figured out that the free wheel ratcheting on the motor would prevent that because I can't turn it around, right?
So now I think I might be able to use a second drive chain drive on the left side to keep the human powered chain from wearing out the sprockets too fast. And knowing how most people don't care, I do not expect to find photos of a rig like that.
So I have got to ask if having a different gear reduction on the left side will affect the right side adversely.
- Like having an effect of the right side chain slip off the sprockets?
- And is there infact a way to mount a second crank set on the left side, to ratchet in the correct direction? Probably not if I want the crank to free-wheel. So I may have to live with left side crank moving when the motor is moving; but at what speed?
- So is there a left side free wheel to hold the sprocket, that I could mount on the motor?
Also I have severe arthritis in both knees so I have to keep the cranking slow. I am going to have to use crank arm shorteners just to keep my knees from bending too much.
And a few other questions about the motor that I am about to buy (cyclone 3000)
- How often should I lubricate the planetary gears?
- Is there a wiring diagram for this motor some where on the internet?
