Hello to all. I have a mongoose malus fat tire with bbshd installed. Everything works very well.
I would like to convert the rear gearing to sram nx eagle 50-11 free hub/cassette?
Not sure about the terminology but my gears thread on to the hub. Several things that might not let this work. Malus is a 7 speed. Can I use only the gears from 50 down til I run out of room?
I would also have to change out the hub of the wheel with fb-2000 8-10 speed hub that will fit in the malus frame. Will the next eagle fit this hub splines?
Maybe someone knows and easier way. A friend of mine has a motorbecane bbshd bike with the 50 tooth and I want to convert my bike.
Thanks in advance
Thanks in advance
