Can a 120mm bbshd be modified to fit a 68-73 bike? If the axle is removed from the drive can it (bottom bracket tube if you will) be sawed down, rethreaded, and install the 68-73mm axle? Asking for a friend
Bbshd 120mm cut down to fit 68-73mm
Hi jangles - I think dkindstrom has a friend who wants to move a 120mm motor they already own to a narrower 68mm-ish frame, and wants to know if it's feasible to shorten the motor.
The answer is yeah, I guess ya could, given a well equipped shop - I don't know of anybody equipped to do it for a fee, other than maybe those people that stretch the BBS02 out. I wonder what a metric cutting die that big cost?
I think I'd try swapping the motor with somebody or look for a used one - first.Last edited by ncmired; 03-09-2019, 06:11 AM.
Originally posted by ncrkd View PostHi jangles - I think dkindstrom has a friend who wants to move a 120mm motor they already own to a narrower 68mm-ish frame, and wants to know if it's feasible to shorten the motor.
Originally posted by jangles View Post
Who can stretch one out ? I have a 68mm bbhsd with 3 hrs on it and would like to put it in my fat bike as I am tired of the Modena already .Fabrication is fun! Build something today. Show someone. Let them help. Inspire and share. Spread the desire.
It should work, the stick out on left side will be 20 mm more. I used a 120 on my 100mm Sturgis Bullets and the pedals are a little wider than usual, and I really don't notice or mind. Not necessarily a bad thing. And, you will be able to fit a locknut for sure with a 120 motor.
Chain line should be same with either.
If you are worried about exactly symmetrical pedals with minimum width, though, 120mm may not work out. That's the tradeoff.
Originally posted by Wilmot296Don’t panic. Lots of my builds have the secondary reduction gear that presses up against the chainstay. If you have at least 12mm of threads showing on the non-drive side then you’re golden.secondary reduction gear that presses up against the chainstay.
