can you run ceramic bearings in bldc motor
    Just wondering if theres any reason you cant run ceramic bearings in a my1020 style motor, the stock bearings are 6001 2rs ZD (2x28x8mm) they are pretty low quality and the front one doesnt rotate freely id like to try some full ceramic abec 9 bearings
ID:	84343Click image for larger version
ID:	84344Click image for larger version
    If it fits I don't see why not. You know you could pick apart the seal on that sealed bearing and replace the grease though right? I'd bet you would see decent results doing that without having to completely replace it
      Cheers for that man i popped the the seals off and flushed it out with degreaser, it spins better now with new grease in there. im going to order a set of ceramic bearing and see if theres any noticeable difference.
