Bafang Brake Sensor
    Bafang Brake Sensor
    Does the tip of the sensor need to be pointing towards the magnet or will it work in proximity to the long side also.
    Is it possible to heat the sensor and put a 30deg bend in the middle
    Sorted this myself.
    I threw away the brake sensor and just went with the gear sensor.
    This works just fine if I need to disconnect the power from the motor and as a backup there is always the on/off switch
      heat would probably destroy the magnetic properties. The magnet just needs to be in close proximity. I had it oriented in a couple of positions...same result
        I use a motorcycle brake sensor wired into the main harness. That way it can be installed anywhere along the brake line for easy hiding. I hate seeing wires if i dont have to.
