Dear all
I have a 350W motor , hub motor front whell
Everything is almost ok , my problem is the battery
I use old laptop batterys , I test then using Litokalla charger/tester
I did a big battery 36V 20 Amp , 10S 10P , but , is not working
I used just cells with 2000 mha capacity after solder then togheter each cell with 10 laptop batteries in parallel , I just able to use for a few kilometers .
I see that some cell get warm and when I did a load test using a cell meter I checked that one group of cell is lower thabn others
I need help to test this cells correctly
Some one could help me ?
thank you
Guil
thank you
Guil
