DIY custom brake rotor size with brackets
    Hi where can I find the formula to determine the brake caliper bracket offset? I want a run a 293mm from brake disc.
    Divide the rotor dia. by 2 which will give you the radius from the center of the axle. Do the same for the old rotor size. Add the difference to the bracket to move the rotor away from the axle that amount.
    A mechanical approach would be to install the new rotor and clamp the caliper in position and mark the new location of the mounting bolts, or drill through the caliper itself into the new bracket.
