It would be great to have a crank arm offset sticky. It appears the Bafang BBS02 crank arms are straighter (less offset) than the Bafang BBSHD crank arms. A comprehensive list of which crank arms are offset more than the others would be extremely helpful with the growing wider tire frames and left crank arm issues they present.
At some point the 100mm Bafang BBS02 is going to be a better choice for 73mm bottom brackets simply because of left crank arm clearance and better centering of the pedals.
