Luna X1 - M600 teardown - PEEK gear replacement
    Great info in this thread. Does the Luna video that was just uploaded track with your experience on the install?
      I found it did. Just have to wobble the gear shafts to pull them out of bearing well. I never realized the threaded holes in sub-assembly was for removal from motor frame.
      • DB60
        DB60 commented
        It helps to remove the little rubber plug at the bottom of the housing when slipping the PEEK gear/bearing assembly back in, it lets the air escape. Just remember to put the rubber plug back in. Also don't forget to put the wavy spring washer back in before the gear assembly. There is no need to risk damage using a press, be patient and the gear/bearing will slip back in.
      #18
      Thanks @paxtana
      Yes, the Luna video is good except for the corny music. I would much rather have the technician speaking as they do the procedure :)
      I could have gone much faster in my video if I had seen it done first
      I went real slow because it was uncharted territory for me :)
        Thank you for the videos and write up. I was wondering if it was quieter enough to justify the time and cost. Also how difficult the replacement was. You answered both of these questions quite well.
          Here's an update on the tools that can remove the spider lock ring.
          Bike Hand
          YC-29BB-2A is a socket with a handle
          YC-29BB is just the socket
          Here's a few pics of both of them
          I got the socket only tool on Ali Express for $12
          https://www.aliexpress.com/wholesale...KEHAND+YC-29BB
          The one with the handle is on ebay here
          https://www.ebay.com/itm/Bike-Hand-Y...e/392274686630
