Smart charger failure?
    So I've been using Luna's 52-volt smart charger for a couple of years now without an issue. But today when I went to charge the battery the display shows 58.8 volts when I plug it in but there's no output to the battery? Nothing I do changes this condition. Is there a 'reset' button somewhere? I've used this charger maybe 40 times in the past couple of years....
    Could be a Bms problem as it controls charge in and power out of the battery
      I had that same luna smart charger fail . I couldnt find any fuses or reset anywhere. I bought another generic 58.8v charger on Amazon and all was well . I suspect some tiny component failed , seems like a cheap Chinese circuit board.
      when luna was back in stock, argot a luna mini charger also , so now i leave one charger at work, one at home
      my battery was working fine , so i knew it was a charger issue
