Is it possible to install a resistor (or like electronic device) to make hand throdle less snappy! Having trouble when in severe tech rocky single track.
detune
Hi 1500junkie,
And welcome to the forum! :-)
This thread might open up some possibilities for you...
https://electricbike.com/forum/forum...d-modification
Regards,
T.C.See my completed Magic Pie V5 rear hub motor E-Bike build HERE.
Since BBSHD, like 73Eldo mentioned, get the cable if you don't already have it. There are more than a few settings for the throttle but for"taming" it I'd make sure the Mode is set to current and then the start current should be set low - I go all the way to 1% and it makes the throttle extremely subtle coming on even in silly low gears...
