This happened on my Luna Cycle Eclipse chainwheel.
Design flaw ?
If you look at the load bearing configuration of a similar device , the Shimano rotor , the load bearing curves are orientated the opposite way around to the Luna Eclipse . The LUNA CYCLE Eclipse curves are designed backwards. The curved sections on the Eclipse are being pulled on as opposed to being pushed on , hence the horrible breakage . Luckily I was not injured .
