I was wondering what the best practices are for battery longevity.
I've heard that it's better to charge your battery to just 80-90% to increase the number of charge cycles / lifespan of the battery. But I've also heard that that is only the case if you're leaving the battery in that 100% charged state for an extended period of time. That if you are using the battery regularly, it's fine to charge it to max and you won't shorten the life. Any thoughts?
I've also heard that occasionally, you should charge to 100% and leave it on the charger for several hours so the BMS can balance the cells. This should be done approximately 5x per year. I'm not sure if this is really true.
Also, I have the option to charge at 1,2, or 3 amp (the charger goes to 5 amp but I was told that my battery can't handle more than 3 by the manufacturer, I don't want to risk higher). Is it better to charge the battery faster or trickle charge it? This is for Lithium batteries.
Are there any other best practices for battery care? I thought this post might serve as a good all-around reference to newbies like myself so we don't diminish the functionality of our new ebike.
