Bought a brand new Z1 with Bafang Ultra M620 motor. All display functions are working normal. My mph is accurate, my trip odometer is working and I can go into settings and reset it. My wheel size is correct.
I've only had the bike for less than a week. The odometer was working perfectly and I was probably up to only 40 or 50 miles. Then I noticed the odometer for total miles is now reading 4,200,000 something??????
Under error codes on the display I got a reading of error code 21.
I have read that this has to do with the speed sensor.
The speed sensor was in fact slightly off and I used the security torx bit to loosen the magnet and properly adjusted so it passes perfectly across the speed sensor.
I turned the display off and back on again.
I removed the battery and then put it back on.
I reset the trip odometer multiple times.
Everything seems to be working perfect except my bike says it has over 4 million miles on it!!
This is extremely frustrating as the bike is only a week old have not contacted Luna officially yet on this as it is the weekend.
The only thing I would like to add is that I did purchase the mini 48 volt charger from Luna that has a toggle switch allowing you to only charge the battery to either 80%, 90%, or 100%.
I charged the battery with the mini charger last night for the first time setting the toggle switch to 80%.
When the charger turned off I turned the bike on and it said that it was only 70 percent charged.
Not sure if the calibration on my mini charger has a problem or not?
Regardless I then switch to toggle switch on the mini charger to 100% and continued charging.
The charger again turned off indicating it reached 100% as the toggle switch was set to.
But when I turn the display of my Z1 bike on it said it was only about 90% charged?
This led me to believe that perhaps my charger was defective I am not sure why the toggle switch does not seem to be working?
Has anyone got an error code 21 but the speed and trip odometer are all working normally the only problem is the bikes total mileage odometer is out of whack what could be going on here?
Is there any way to reset the odometer?
I appreciate any help from The forum members and or luna staff who may be monitoring.
Sincerely
Sincerely
