How to Check for Flat Tires
    1. Listen with your ears: After inflating enough air, put the inner tube to your ear and turn it around slowly, there will be a "squeaky" sound of air leaking at the air leak.
    2. Touch it with your hand: After you get enough air, gently hold the inner tube with your hand and turn it around. There will be wind blowing out of the air leak, and your hand will feel cool.
    3. Water test: put the inner tube into the water after inflating enough air, and air bubbles will appear in the place where the air leaks. (Very tiny air leaks can be detected)​
    Originally posted by AOSTIRMOTOR View Post
    HOW TO CHECK FOR FLAT TIRES​
    How to check for flat tires.. That`s EZ.. How could you not know you have a flat tire?.
    I think what you meant to post is how do you check for under-Inflated tires
    • AOSTIRMOTOR
      AOSTIRMOTOR commented
      Because I encountered this situation on the road once and found that the tire was punctured by a sharp object while riding, but it was detected by the third method.
    • nate77
      nate77 commented
      I agree that the title does not reflect the content. I always use the third method to find the hole in tire
