Onyx Hubs uses them, but in a high end hybrid bearing setup. I like the full floating axle setup. Load and drive carried separately. I'm not sure why anyone bothers with ratchet pawl type clutches. Multiple pawls, but only one engages at a time, noisy, slack between engagement points. Sprag clutches are used in automatic transmissions. They're off the shelf tech. Why can't we have nice stuff.
Sprag clutches, silent, strong, instant engagement.
Originally posted by Retrorockit View PostOnyx Hubs uses them, but in a high end hybrid bearing setup.
https://www.naturalnews.com/2023-01-...-earliest.html
Remembering the 1930`s-1940`s Why should I care I`m not a Chinese Journalist.
Not that it's important, but has anyone taken apart the BBS motor clutches to see whether they are sprag or the ramp-type overrunning clutches.....
Sprag:
Ramp-type:
BBSHD has pawls at the pedals, and a roller bearing ramp style in the plastic gear.. The ramps are just formed into the outer bearing race.
The ramp roller clutches can double as a roller bearing. Espcially since they're usally under no load when released. The ones in the BBSHD are nice because they have separate roller elements. The TASDZ2 not so much.
It has many known quality and strength issues. I own one and have hardly ridden it. TSDZ2 people just seem to accept a bunch of crap that doesn't exist in the BBSHD world.
IMO it's a 350W moyor being run at 750W. It has no cooling as it comes. This can be fixed. Endless sphere has an endless thread on these things. Stripped plastic gears, and snapped pedal shafts abound. if you want to add a throttle a new controller and wiring harness are needed. Those may not come programmed for a throttle. You may need to fabricate a harness to program it ( that's where mine is at right now). You can geek out on the open source firmware (most of the thread is related to that). Basically fixing them is a hobby unto itself. Look before you leap. Compare what you see at the ES TSDZ2 thread to what you see here. I donated a simple cooling mod there.
Hi, I was made aware of a new offering over at BMSBattery today: "SDZ2 Torque Sensor Central Motor". https://bmsbattery.com/home/803-sdz2-torque-sensor-central-motor.html Seems like a an attractive alternative to the Bafang BBS, $50 cheaper, with torque sensor, better installation guide etc...
I think the quality of the bearings is questionable, and since some are noisy, some not, somr break others don't I suspect the machine work is inconsistent also.
I'm too busy riding my BBSHD to be bothered with it.
I think they got sued by Bafand and had to add a sprag. or maybe they just did ti on their own (unlikely from what I've seen).Last edited by Retrorockit; 01-29-2023, 05:49 AM.
