I decided to try this because 11 speed chains seem to be strong enough for a BBSHD, and last quite a bit longer (no idea why). Supposedly cross chain better too.
I'm going to put a little bit of "theory" out here because there are some "reasons" this might not work.
1- 8 speed chain is wider on the inside. This is true. 3/32"(2.38mm) inside. 9-11 speed is 11/128"(2.18mm) inside. Difference of .008". The teeth on 8s cassette are 1.8mm. Some cassettes with alloy cogs could be wider but they would all be made for 9-11s and not 8s specific. It's possible that you might find a 2.3mm wide chainring. if it has some wear on it it should work anyway. But 9 speed has been around for 20 years or so. Unless you go to a 3/32" single speed part (some Surly rings) you aren't likely to find these. But 2.1mm has been the standard for a long time.
2- 8 speed is wider on the outside. (7mm) As they add gears to the cassette the chains get narrower and narrower on the outside. The rear derailleur moves the chain centered on the guide pulleys, not pushing it from the outside like a front derailleur. The 11s chain will have no problem passing through the wider 8s derailleur and going to the right gear.
3- The 11 speed chain is narrower (5.5mm). That's quite a bit actually. But does it matter? Can it fall down between the cassette cogs? The 8 speed cassette has 4.8mm center to center on the cogs, which are 1,8mm thick. That leaves 3mm spacing between them. So it's not going to happen.
Now let's get back to reality. I bought the 11s chain and tried this Specifically a Wippermann 11sE Ebike chain. It's going on a BBSHD with a flat 50t Surly stainless steel chain ring (2.1mm). With a Shimano HG400-8, 11-40t cassette, and a Vintage Rapid Rise XTR deraillauer that may be 8s or 9s I'm not sure (M860) and a matching Shimano 8 speed Revoshifter so I can throw a bunch of shifts at once. This bike also has the Zip Tie Mod. So shifts can be made any time the bike is moving, pedaling or not, up or down, any number of gears at once. It has a toothed idler chain guide to keep the chain from flying off. if there is a problem with this chain conversion I will probably find it.
I installed the chain with the Connex link they supply with it. I had not been using them on this bike, but the smooth shifts with the Zip Tie Mod got me to try it again.
First ride I had chain skips in the top 3 gears. I rode to my favorite LBS because he works on whatever comes through the door and has probably seen it all. HE diagnosed it as the Connex link.
I don't have a tool to rivet the 11s chain. Mine just does 8-9 speed. The solution was to pull 2 outer plates, and pins from a piece of unused 8 speed chain and use them as a riveted master link for the 11 speed.
So the plates on the Connex have gotten thinner and I guess it distorts when cross chained under due to the egg shaped holes.
After getting rid of the Connex (or any other tool less link) this is working beautifully. It feels smoother and shift adjustment seemed easy because the narrow chain doesn't rub if it isn't perfect.
it seems to pop right into the next gear when shifting (LBS gut noticed this too). I haven't taken a long ride since fixing the connector issue. But the test ride around the neighborhood before it rained was excellent. full power in all gears, even the corsschain ones, and no skipping at all.
