Snow is on the way. Are there any inexpensive fat tire bikes out there that are good ebike candidates?
Inexpense fat tire bike recommendations?
If you think you could be happy with a 3-inch tire, the mongoose terrex hardtail from Walmart might work for around $160. If it is not in stock, you can order it.
Once you get it running, it benefits from several upgrades whenever you save up some extra cash. It has a front disc brake, and I would swap-in a larger diameter disc, and also upgrade to hydraulics ($120 from Luna?) And also Thudbuster seat (or Suntour NCX).
- Likes 1
Harold see this post by Eric Luna: http://www.electricbike.com/forum/fo...the-extra-cost
"- The BBSHD was completely redesigned, almost every part is diffrent.
- The BBSHD uses much beefier components, and a beefier controller."
I have enough parts left over from the first kit, that it's less expensive to piece the parts for this build. The mighty mini battery has been working out great, so I would go with that one again. The bike arrived Saturday, got it together with no issues. I'm wating for Luna to restock the Shimano E disk brake kit. Also wating for the Sturmey Archer 3 speed hub.
- Likes 1
