PAS hall transistors fried
    Well I fried my PAS hall transistors. I was cleaning up the wiring on my ERT 3500w 72v build and got a couple of wires crossed and killed my PAS hall effect transistors. They are marked with '1401i'. you guys at Luna got any? Maybe a hall sensor board out of a trashed BBSHD? Anybody recognize the chip nomenclature? The attached picture is of the PAS sensor board located in the reduction housing. Any help would be much appreciated!
    Yikes
    I'm having similar issues
    it started with a battery connector that was going out I removed the controller to solder the wires
    when I put it back together I got the 'error 08 controller reports
    I tried another controller and got the same
    doing a complete breakdown I noticed damage to one wire on the 4 wire plug to the PAS board i removed the circuit board and soldered connections
    I didn't screw the circuit board back I tried pluging it in to test worth no luck
    here is one big question
    why is that circuit board there?
    the BBSHD has 3 areas
    the motor core has the hall sensor board
    the controller area has the 3 phase wires the 5 pin hall sensor plug and the 4 pin PAS plug
    The third area is the main steel gear and clutch and the PAS circuit board
    mine has cler silicon over the circuit and the white rubber silicon
    the main gear area I'm guessing had the least amount of heat but the biggest water entry potential
      Look at this https://fasterbikes.eu/en/parts/286-...ms-1parts.html or http://www.greenbikekit.com/bbs01b-b...placement.html
      Click image for larger version  Name:	bafang-bbs-pas-sensor-board-8fun-ms-1parts.jpg Views:	1 Size:	35.4 KB ID:	55216
        This is a long shot: https://www.mouser.com/ProductDetail...r8O2BzAdimI%3d same as https://www.digikey.com/product-deta...401-ND/2371083
        Another sensor with a 1401 in it https://www.digikey.com/product-deta...401-ND/5270608
          Big thanks
          I wad glad I had another controller to test to rule that out
          I'm planning on getting a new motor and rebuilding this one
            Get it here:
              thanks a lot for the links, i appreciate it a lot! also thanks for all the information, may i ask here questions in case i would have some? thanks again!
              • commuter ebikes
                commuter ebikes commented
                Yes, you can ask questions here.
              Don't put that PAS in the bin to quickly
              I was getting the 'error 08 controller report'
              after reinstalling the controller
              I removed it to clean up my BatMan connection and connectors
              I got display but no PAS or throttle cue the panic
              disclaimer I've replaced the controller already so I've prolly pushed/pulled the the 4 pin PAS and the 5 pin HALL plugs 5 times already
              after perusing this fine forum I opened her again to look at the wiring
              the PAS wiring had a couple cracks where it went through to the main steel gear both cracks had broken strands
              the pins to the HALL circuit board on the motor core side looked bent so I opened the motor core to inspect
              they didn't look that bad looking through the rectangular port but when I set the core on a level table the pins were bent in unison upward and to the right
              definitely from the repeated installs
              I straightened them with linesman pliers and cleaned them with rubbing alcohol
              reassembled it now throttle works but no PAS so it was the connections and I was half way there
              I cut the 4 wire PAS cable and removed the circuit board
              I desoldered and cleaned it and delicately soldered 4 new wires
              reattach the board put the wires through to the controller side and crimp to the plug
              slap it back together it not only worked the throttle that was acting sketchy the last few months was working great on a test ride in hard rain
              It was was the greatest comeback since Lazarus
