Hi all,
I'm currently a senior selective high school student studying engineering studies as one of my subjects and I've be selected to do an open design and research project on designing a new propulsion system on bicycles with the criteria of the motor being light, safe (be within the capability of the existing braking system) , durable(lasting more than 5 years), efficient, must be able to attach and detach with ease, no changes of the current braking system of an ordinary bike and cheap.
Thus, I'm balancing out between geared and gearless hub motors as whilst leaning more towards geared hub motors for its light weight option + efficiency yet I'm quite torn for disregarding gearless hub motors as they are quite durable and is relatively cheaper but it is a lot heavier.
Whilst researching on these topics I've come the the conclusion of most likely choosing the design of a front geared Brushless DC hub Motor.
However, I'm thoroughly confused at some sites suggesting that all hub motors are DC Brushless, which I can see being applied In the gearless Hub motor, but what about the geared hub motor? As it operated on planetary gears how is it classified by any chance as a DC brushless motor?
Also, in terms of a geared hub motor how durable would it be if one replaces the plastic teeth with steel teeth? Would it last more than 5 years without maintenance or would that be stretching it?
Thank you all so much for reading this and I urgently look forward to your Replies!
Kind regards,
Ross
Kind regards,
Ross
