I am assuming they can. If they can what tubeless kit do you recommend.
Can rims on Luna KHS Deluxe 500 be made tubeless. Tubeless kit recommendations?
There are no standards for rim diameter and tire bead diameter, so some tire/rim combinations won't be possible. As an example, the bead diameter on my 45 North tires was so large that it would never work tubeless on my rims. But Surly tires worked by adding a little foam insulation filler. Swalbe tires worked with no filler and beaded right up. So unless you are willing to do a lot of screwing around, it might be better to pay a bike shop to do it. As far a sealant, I've had the best luck with Orange Seal. My friend swears by Stans sealant, which has a much thinner viscosity. Unless you are extremely lucky, you are going to need an air compressor to get it to bead up the first time.
