Extreme Hill Climber Fat Tire MTB Project.
    Here is the Park Tool HHP-2 headset press in action. The Chris King cup press adapters are the gun metal gray attachments next to the bearing cups. Click image for larger version  Name:	IMG_2410.JPG Views:	1 Size:	220.2 KB ID:	43113
      Here is the crown race installation tool in position. The Chris King base plate adapter is the gun metal gray attachment next to the crown race.
        I drove the crown race down all the way.
          Here is what I have so far. I am moving on to the BB and crankset which is my favorite part of the bike to work on. In this photo, you can see the reverse rake (front tire O.D. 31.5", rear tire O.D. 30.5"). I have not adjusted the saddles yet from when the bike had equal diameter tires.
          Click image for larger version  Name:	IMG_2438.JPG Views:	1 Size:	2.34 MB ID:	43119
            Emailing back and forth with Vladimir S. at Zelena Vozila, I changed my order from three custom width bare axles to two new Cromotors assembled with the custom width axles, as well as a spare bare axle with the same wide dimensions. These will be spare motors and a spare axle for the bikes above. I am also got some spare rotor mount flanges and axle snap rings.
              Here is the Park Tool BTS-1 bottom bracket tapping tool in use. The cutting oil was pretty messy.
              When I pulled out the taps, it had a lot of metal shavings.
              The new bottom bracket cups threaded in very nicely.
              Click image for larger version  Name:	IMG_2445.JPG Views:	1 Size:	2.46 MB ID:	43168
              Click image for larger version  Name:	IMG_2460.JPG Views:	1 Size:	1.64 MB ID:	43169
                Marine grease on the Moonlander splines and spindle: Click image for larger version  Name:	IMG_2484.JPG Views:	1 Size:	1.83 MB ID:	43187
                Click image for larger version  Name:	IMG_2471.JPG Views:	1 Size:	235.5 KB ID:	43188
                  Button head M5 bolt on Singleator for motor clearance:
ID:	43190Click image for larger version
ID:	43191Click image for larger version
                  • calfee20
                    calfee20 commented
                    I put my Surly Singleator on the other day just for a look and saw there was no clearance. I was thinking of a flat head with an Allen but this may better. I am thinking of adding a sealed bearing to the rig.
                  • commuter ebikes
                    commuter ebikes commented
                    When I was assembling with the Singleator today, the SS pulley bushing fell on the garage floor, and I almost couldn't find it. What do you mean by a sealed bearing? I might not be so lucky if the pulley bushing falls on the floor again.
                  #99
                  Final chain setup. I removed 10 links from a new chain.
                    This was after the first test ride. The gearing is very low.
                      With that small chainring, I can imagine it's on the low side.
                        I had the idea then thought someone must make it. So I did a search. http://www.jensonusa.com/Rear-Derail...ulley?cs=Black
                          Wow this is all looking really good, now that's a bike I would feel confident riding at speed knowing it's not going to fall apart. Do those huge tires absorb bumps and rocks off-road? To be honest I've never ridden tires bigger than 2.5 except on my enduro motorcycle but it of course has a lot of suspension.
                          It's too bad Lawill Leader forks don't fit fat bikes, I could imagine a set of those on one of those frames might look nice and ride pretty good off road.
                            That is a sweet find! I will put those on my list!
                              I just went out to see how fast I could pedal the bike. I did a burst with the highest cadence I could produce, and I got up to 7 mph.
                              With sustainable cadence, I could ride up to 6 mph.
