Can I charge a 52v battery with a 48v charger?
    Is it possible charge a 52v battery with a 48v charger?
    And if it would work, what voltage would it charge the battery to?
    I currently have a 3 position 52v luna charger but would like to have a smaller quieter charger to top up at work.
    Thanks,
    John
    The 48v charger will stop at 54.6v while the 52v will charge to 58.8v, I believe this is fine for a top up at your work but not for a regular balance charge where it needs to go to full voltage.
    Lets see what the experts say,
      I would purchase the standard charger, they're alot quieter than the mini charger. The 48 volt charger would only charge you pack to approximately 70%, If your pack was lower than 54.6 volts then yes it would work.
        Hi, i have a 52v battery pack (actually i have 2) so the charger only charges to 75%, what i did was connect the charging port to the other battery packs + and -, and it started charging normally... So you can i ques charge a 52v pack with a 48v charger... (O dough i did find (easily) a 54v charger)
        Marry Christmas! & Santa
          No, you must use a 52V battery charger to charge a 52V pack Tell Popeyes.
