Need stuff
    Need stuff
    I have a Ranger bike, 250-watt, 1000 amp hr. and I need a battery and charger. Can Electric Bike provide this?
    I can send a photo of the battery and a charger that works, if that would be a help. Will need instructions as to how to add a photo.
    Nominal voltage and battery chemistry is needed. For example, 48V, LiMn. Also, you can look at the type of connection used on the charging (cable?) of your battery (e.g., mini XLR) so that you won't have to change your connector.
    To upload a photo, type about 10 or more characters, then use the icon which is a drawing of a paper clip attaching a sheet of paper (shown below) in order to "Upload Atttachments". It is best to size your photo to less than 1.5MB. Upload the photo and then choose a size (Medium, Fullsize, etc.).
    Click image for larger version  Name:	Capture.PNG Views:	1 Size:	1.3 KB ID:	40335
