I have the BBSHD on a mountain bike and want to put a 52 tooth chainwheel on it. I see that the 52 is offered as a part for the 02 motor but not the HD. Is there a reason for this?
Chainring
Originally posted by Scott S View PostSpeaking of lekkie. When might you have the 46 tooth for bbshd paxtana??
How about that ugly heavy stock chain ring just to tide you over. It's $25. http://lunacycle.com/bbshd-46t-stock-steel-chainring/
Originally posted by calfee20 View PostHow about that ugly heavy stock chain ring just to tide you over. It's $25. http://lunacycle.com/bbshd-46t-stock-steel-chainring/
If I put a 52 volt battery on the 02 setup, replacing the 48v that’s currently on that bike, will I gain speed?
Of course you will. I start out with 58 volts or so and the bike is nice and lively but when I get down into the high forties it feels a little sluggish. I am sure you will feel the same way with a 48 volt battery. When the voltage drops you will feel the difference
If the batteries have the same amp/hours the 52 volt battery will give you more watts and more range. If you could test two identical bikes one 52 volts and the other 48 I don't think you would want to ride the 48 volt rig. Before people start hollering at me let me say that you could get the same feel with 48 volts but it would require more amps and cut down your range.
One bike has the 02 , 52 t, 48v. I want to go faster so my idea is a 52 v which I have.
other setup is HD, 46t, 52v, . I want to go faster so my idea is 52t.
A m I on the right track here?
There is practically no air resistance below 12 mph. Say you need 350 watts to go 15 mph. A rule of thumb inverse square law says that to double speed you need 4 times the power. 350 X 4 = 1400 watts. This sounds reasonable to me because it fits with what I am seeing with my BBSHD. You may be at a point that another 5 mph is out of reach for your motor
I just got an edge 1500 going and it is crazy fast but it doesn't climb like a BBSXX.
