30+ mph
    30+ mph
    Best way to get to 30mph+?
    all suggestions welcome- BBSHD
    BBSHD with a 48V battery has no problem getting my tank of a fat-tire bike to 30+...
      That with or without pedaling? Mine is pretty consistent at 25mph
        Have you fiddled with the controller parameters?
      I can't pedal that fast so it's definitely throttle only. I've gotten it as much as 35mph [and it was still accelerating slowly] a couple of times but that was more than fast enough for me...
      It may be your gearing. My top gear is 39t chain ring and 11t rear cog...
        Reduce mass, air resistance, and mechanical drag (tires, hubs, brakes) where possible.
        BBSHD / BBS02: Nexus / Alfine 8: 1 2 3 4 5 6, Rohloff: 1 | PHOTON: Alfine 8: 1 2
          With the exception of hubs mine is terrible on the rest
        What kind of suggestions do you have with configuring the controller?
          What is your high gearing and tire size?
            In my case, a BBSHD pulling a 42 / 18 front / rear gear ratio, 1:1 via the IGH through 700C-38 tires works out to 55 gear-inches - with this setup I think the motor RPM is maxed out on level ground, at 32-33MPH. Being just at the peak motor RPM means that the bike maintains speed pretty well on slight inclines. I don't know how well it would pull another 10 gear-inches.
            And, no, I can't pedal anywhere near that fast (~140-150 cadence) so, it's all motor.
            Unfortunately mass (~380lbs), air resistance (upright barn-door), and mechanical drag (IGH) are all putting a hurt on the speed.
              I am tuning the bling ring on the Roam 2. The tires are 700x38
                Originally posted by bootaggie View Post
                I am tuning the leakiest bling ring on the Roam 2. The tires are 700x38
                So, a 42 front - what top speed do you get on the 17 tooth rear sprocket (4th smallest) on level ground?
                P.S. yeah, it's gonna be a little too cold to perform speed tests right now ;-)
                  About 25. Just starting to get little cold in Texas
                    42 / 18 ≈ 2.33 vs. [mine at] 39 / 11 ≈ 3.55 so my max speed limited by motor RPM would be ~1.52x yours (i.e. you have ~66% my maximum). So let's say I can go 40mph you'd be limited to ~26.3mph
                    I'm pretty certain you'll need a higher ratio to exceed 30mph...
                      My bike came with 700C 38mm tires; I am thinking about getting wider 700 x 45 mm tires. How would that effect the top speed? Probably it won't affect max speed but I would just get better rider comfort and tracking right?
                        1/4 inch wider I'd think would soften the ride, depending a little on the pressure. Dunno about the top speed - hard to discern what a tire will do.
                        Like me I guess, my bikes are facing old age. I'm finding it hard to wring out 30mph anymore and I don't know why (probably drag).
                        'm focusing more these days on range and using 20mph now as my common reference / test / comparison speed.
                        • tklop
                          tklop commented
                          ...I'm focusing more these days on range and using 20mph now as my common reference / test / comparison speed.
                          Yeah--anything above about 16 to 18 mph, and the wind-resistance begins to build exponentially.
                          Unless piloting some ultra-aerodynamic bubble-bike, we're really only turning battery energy into headwind above about 20mph.
                          I know it's not so easy to slow down these days--it's sort-of a rush-rush-rush-rush-hurry-up world. But there's definitely advantages to slowing down--not just the obvious boost to effective battery-range.
                          I find I am more fully immersed in the riding experience--more able to enjoy the scenery, etc. if the wind in my ears isn't deafening--and if I'm not having to squint into a storm-force blast of wind (and dust and bugs)...  In fact, find I rarely get bugs in my mouth or eyes at all if I'm keeping at or below 15mph or so... Also, I find that I actually have more physical endurance--so that even though riding a little more slowly, I can actually cover a greater distance. Because it's less stressfully exhausting, the slower I go, the less I have to "ride my reflexes"--so that means I can relax more; and can therefore go considerably further on any given day. Reductions in speed benefit range--in terms of both battery and body...
                          Sure--admittedly--more often than not, I'm buzzing around closer to the 20mph end of things when I'm just commuting. But if I want to take a longer trip, it's incredible what a two or three mile-per-hour reduction in speed can do to my effective range...
                          I'm certain my 4KW Cyclone will propel my bakfiets well over 30MPH--and whenever I plop the DD front-wheel hub-motors on it, its potential top speed might be faster still--I've really no idea. But on that machine, fast genuinely isn't fun--it's terrifying! I've currently no machines which I'd feel safe riding on at 30 mph sustained.
                          But certainly, on the right machine, fast is fun--no doubt about it. And I'm not here to rain on anyone's parade (though if it does rain--it's a good idea to slow down--it's not just your own controllability, it's the visibily of other drivers you gotta take into account--but I digress)... So--yeah... For all you speed-demons--hey, go for it! I guess for me, if I really want to go faster on e-transport, I'll just take the NS train. It too is electric (powered by 100% wind-energy), and hits 140+kph between stops!  :-)
                          I'm enjoying reading the discussion and seeing folks' experiences and strategies...
                          Best of luck with your projects, everybody!
                          Take care,
                          Tklop
                        #15
                        My bike came with 700 c 28 tores the largest i could get in the frame was 32. I ditched the the rim and went to 27.5 (650b?) A schwalbe energizer plus with taller sidewall and 2.00 inch tire made the handling much better . no sacrifice in speed. Full rim- tire diameter even the same. Comfort increases with lower pressure, but extreme efficincy loss. Keep pressure up.
                        Range has been most affected by adding a fairing ( solar) reduced wind resistance by 3 watt hours per mile at 20 mph. And top speed by ? Over 36 on bbso2.
                        Never charge.
