Stans no tubes with tubes and tube talc
    I went to the LBS to pick up a tube and was chatting with one of the mechanics. He pointed out that when using stans in tubes the tubes have a lot of tube talc inside and that you need a lot more stans since a lot of it immediately balls up with the talc - especially with a fat tube (26" x 4.0-4.8").
    I said why not rinse out the tube first?
    I rinsed the tube insides with RO water. The first flush there was a ton of talc. I had put about a liter of water in the tube and it was a thick white slurry coming back out. After about three or four rinses most of the talc was out.
    As always, YMMV...
    Makes sense. Good tip!
      I have not tried the Stan's in tubes yet because the green tire slime (in conjunction with 7 tire liners) has been working perfectly for me. Another additional benefit of the green slime is that it lasts longer in the tube (2 years as opposed to 6 months).
      I wonder if talc interferes with green tire slime. It must not because I am not rinsing and the green slime is sealing holes from nails.
      I think I might try rinsing out the talc and using less tire slime in order to save weight.
