Dump find
    Dump find
    I was getting wood chips for the blueberries Saturday and look what I found in the dump.
    Check out that high tech rear suspension. What do you think I should with it? Maybe it could get a BBSxx or a small hub motor. Maybe it should go back to the dump!
    Always wanted to try one with the rear shock like this. I'm told they don't work well and while that might be true compared to a FS MTB I would guess it's more than enough to soak up the usual hits from casual road ebiking.
    Is it a softtail? Does it have a pivot point for the rear chainstay at the BB?
    • calfee20
      calfee20 commented
      There is a pivot.
    I believe it has a single pivot so not really a unified rear triangle but unified rear V. At the least sell it off and put it toward ebike budget.
