Is it possible to connect a solar panel to a 48V PANASONIC 13.5AH SHARK PACK so I can charge during use?
Solar charge during use
Just what motor do you have?. You do realize the motor on that bike in video was a 250 watt motor. I didn't watch long enough to find out what volts it is using but I would go out on a limb and say not more than 36 and possibly even less (24?). Start searching panels for the output you are going to need. It is going to be larger than that panel in the video guaranteed!
As for configuration you simply cannot be pulling more amps from the battery than the solor can provide to the battery. If I was on a long cross country trip with a trailer I would carry a small generator and a charger and charge an extra battery on the go or at breaks that way. LolLast edited by Scott S; 08-12-2018, 07:10 AM.
My application is Wireless Internet Distribution with a 48v/38w max draw transceiver. The video suggests that charging during operation is possible. I'm trying to confirm that and whether it would need any special wiring to accomplish. The nicely made battery pack creates a plug and play battery module that is ideal for my remote communication application and should supply days of runtime even without sun.
38 watts. Heck a spare battery is all you need for days of operation. Why cart around a big arse solar panel. You will never have access to an ac outlet to charge a battery?
A small generator and your charger is all you need. If you are using the WID while riding you would still need to keep motor amp draw and your tranciever draw combined below the solar panels output to charge on the go!
Originally posted by jnrhome View PostIs it possible to connect a solar panel to a 48V PANASONIC 13.5AH SHARK PACK so I can charge during use?
You will need a solar panel array capable of providing the wattage you need (your load, plus an extra 75-100 watts for battery charging) and most likely a boost converter to get the voltage to the same as what the AC charger that came with your battery provides to the battery. You'll also want to use the same connector as the charger that came with your battery uses.
Forget solar, it's not worth the hassle. The one exception would be to use solar to charge your iPhone/iPad and other electronic devices -- it's relatively easy to find small solar chargers that have USB lea
my websiteLast edited by JonWalter; 03-18-2021, 05:45 PM.
I recharge my bikes using solar 100% of the time, but it's solar that is grid tied at my home, so I just plug into the closet wall outlet. One time, just so I could say it was DIRECTLY alternative energy powered, I charged down at my hydro electric power shack before it entered the grid. So the force of the falling water (90 GPM, 147' of fall) was the direct source of the energy requried for that days ride, but that was just a one time stunt. Get a grid tie home solar system and you can then more or less claim you have a solar powered e bike. My bike is powered by a combination of wind, solar, and hydro, all stored in the grid, and I always produce an excess amount of power on a monthly basis, so I feel pretty guilt free about my power source, mostly it's fun to brag about when some e ignorant person claims an electric vehicle of any sort is only shifting the load to a big power plant, not in my case, it's free power, and more is coming tomorrow, time to go for a ride and use some up!
