Charger adjustment
    Charger adjustment
    I have an long standing issue with my charger that I want to adjust. I am not totally sure which pot on the advanced charger I need to use to get what I need. When my charger is used on the 100% setting (it has 3 levels) it only charges to 53.7 volts instead of the 54.6 it should. The longer it is left on the charger, the lower it goes. It has done this since new. The battery is a 48 volt 20 ah with Panasonic PF cells. I used to have a cheap 48 volt charger that I could plug into and it would take it the rest of the way when I needed a full charge. Unfortunately it died so I need to get my Luna charger to go high enough to properly balance the battery cells.
    https://www.youtube.com/watch?v=taNI-7x5BoY&feature=youtu.be Charger fine tuning basics https://www.youtube.com/watch?v=H9ENLcYFn54&feature=you
