EggRider Display Configuration Help
    does anyone fiddled with this display? i got mine for a week now and I can't seem to make it work the way i wanted.
    What I want:
    - road & offroad profile for pedal & throttle (speed lock at 28kph on road & 45kph offroad
    - battery indicator accuracy for my 52v 13ah pack
    - the pedal & throttle kick is not as smooth what i had using stock bbshd display
    Issues:
    - the app shows road profile only
    - I entered 52v in the advanced menu but on my display its kinda all over the place "sometimes it says 90% then i will check again and it will show 99% then i tried turn off/on the display then it will show 100%. Not sure if its reliable.
    - it seems that it didn't inherit the configuration i put in the motor using old LCD display. Though i can see the values i entered long before.
    My best purchase of 2019 added stealth factor to my emtb :)
    honestly not being a wise guy, but have you tried checking the online manual (https://bitbucket.org/eggpower/eggriderv2/wiki/Home), updating firmware, manually setting the programing from the phone app, etc?
    the profile change may need to you go into the advanced settings in the app, display might need to be calibrated (not just selecting voltage) to your specific battery if you havent done that yet, and apparently the firmeare has recently been updated to allow the display to read current controller setting if i am reading right.
    this specific page, if you havent looked already, may be useful: https://bitbucket.org/eggpower/eggriderv2/wiki/setup
