Metal compatability
    Metal compatability
    Will there be any problem with metal compatibility of a Bafang BBSHD mounted in the bottom bracket of my aluminum frame bike?
    Oldguy
    While galvanic corrosion can occur between steel and aluminum, the parts you replace we're also steel. So are bearings in hubs, bolts, etc. Long term, sure, that will eventually corrode. But not a unique situation because of the kit. Just, a trade off with aluminum frames in general.
    Then again, they don't rust. So corrosion life benefits exist with aluminum frames, too.
    At 3 years I see no such corrosion. I wouldn't worry about it.
      I work in aviation industry and got my hands on some dissimilar metals grease. Bloody expensive and told that silicon grease is probably just as good if not better. Like JPlabs, no corrosion issues whatsoever.
        It's worth considereing. The grease is a good solution. It keeps water and air out, and separates the 2 metals. When Aluminum corrodes it gets bigger which locks up the threads something fierce. Aluminum oxide is also very hard and very abrasive. It can require destructive techniques to separate part that have corroded together. Especially if salt is involved. I've spent a couple hours removing each steel bolt in an aluminum housings to avoid breaking them off in an engine block.
          • JPLabs
            JPLabs commented
            I just use antisieze for bolts, I think silicone grease for the install is a good idea!
