Kona Cinda Cone Small Frame BBSHD Build
    Was debating a BBSHD build on the Kona Cinder Cone size S frame. Anyone have any experience and advise with this model and build experience? To me it looks pretty burly frame for the application. Also, I am 5'6" and a little concerned about battery mounting up with bottle cage mounts on such a small frame too. Past knowledge really appreciated
    Anything from anybody
      You should measure the triangle opening to determine what batteries will fit. The type of range your looking for will determine the battery size. If the battery takes up the entire triangle you could mount the bottle cage on the bottom of the down tube.
      on my wife’s small frame Specialized I used a mighty mini battery mounted to the seat tube. This clears the bottle cage in the stock location on the down tube.
        Yes measuring triangles opening to determine the batteries would help....It will clear the bottle cage in the stock location on down tube MYKFCEXPERIENCE
