Controller seems stuck in on position.
    When ever the battery is on my bafang 750W bbs02 takes off when peddles are moving, I have no way to change power level or change to no pass. Trying to program has no effect. Not sure where to go.
    There might be a short in the controller wires, someplace. There are two wires you can connect directly, to operate without a display connected. If same wires are shorted on yours, I guess it would be always on.
    Unplug the display and see if it stops doing this. If so, bad display, probably. If not, perhaps a short in the wiring harness.
    Something to try...good luck.
    Spare harness is available...
