Tklop I haven’t found a setting for battery chemistry, but there are a lot of other options available. The 48v controller assumes you are using a 13s, so maybe changing the setting to 14s with the new display would make it the bars more accurate. Aside from that, there are a bunch of features you can display like a remaining watt meter, voltage meter, and state of charge indicator. Check it out
https://github.com/OpenSource-EBike-..._Battery_Setup
