Cruise Control Gadget for Throttle Wrist Fatigue
    I am only able to use a throttle on my ebike kit and not a thumb control and I often do 100 miles+ a day. Boy, does my wrist get tired! Well I have seen inexpensive motorcycle cruise-control. gadgets for this (and one person even mentioned an ebike in a review), and was wondering if anyone has installed such a gadget? Here is a pic of one on a motorcycle. Some of them look like they automatically shut off if you hit the brakes.
    Wouldn't it be easier just to go with a thumb throttle?
    For what it's worth I have the Bluetooth controller on cyclone and it has an option for this automatically. It just stays on like that but can be sketchy to enable.
    • tklop
      tklop commented
      I too use the Cyclone BT controller--and its auto-cruise...
      On my bakfiets, the front-motors' KT-LCD3 controllers also have auto-cruise (also can be activated via the Up/Off-On/Down dongle's button).
      If I'm on smooth ground, I usually have no problem getting both systems "auto-cruise" to engage.
      But getting "auto-cruise" to lock in when it's bumpy--can be extremely difficult. To activate it, I've got to hold the same throttle-setting for several seconds (eight I think)... and trying to hold either a thumb or twist-throttle steady, while my handlebars are bouncing around--is quite a challenge!
      Is that what you meant by sketchy-to-enable?
      Anyways--yeah...
      Cruise-control is a big help. I'm not a doctor--but it seems obvious to me that we should try to look out for ourselves. If something hurts, sustaining it for hours cannot be good. Endless wrist-twists? I'm thinking maybe carpal tunnel syndrome--or possibly something else... Not nice, at any rate. And the point is, we want to enjoy e-bike riding--not give ourselves stress-injuries!
      I mean more like it's sketchy to even turn on that feature, because if you wreck then the motor may still be going.
    • tklop
      tklop commented
      Oh, okay--I understand.
      The auto-cruise cancels via brake-switches, or throttle-activation--but potentially, yes--you're right. That could be sketchy!
      I've imagined that scenario before--and have plans to install a "kill switch" on my bakfiets.
    If you'd like to try something electrical, this looks interesting... Just have looked at the link... no actual experience with it.
    http://www.ebikessf.com/clyte-cruise-ctrl
    Regards,
    T.C.
      Also for what it's worth, the Golden Motor Hub kits have a cruise control button as part of the kit. Cruise is deactivated when brakes or throttle applied.
        Try this device. Available at your local dirt bike shop. It is called a Cramp Buster and is available as shown or with a wider tab for your palm.
        • tklop
          tklop commented
          Good call.
          This looks like a near-perfect solution for the original poster--similar to what they were showing in their pic--but simpler.
          Plus, the "Cramp Buster" is so inexpensive, that even if it doesn't work out--the original poster probably won't feel too bad about the lost investment.
