Frames that are set up for the Bafang M620 motor and stealthy
    Originally posted by KaroKönig View Post
    Hallo, I can recommend you the Stereo Hybrid Intube framework of Cube. They are well made and can be adjusted with a little effort for the M 620.
    Hi,
    Your link shows a regular MTB frame, not Ebike frame
      if you open the website you have to look under hybrid-frames and then under intube.There are several in 29 inches and 27,5 inches
ID:	104308Click image for larger version  Name:	IMG_0068.JPG Views:	0 Size:	2.30 MB ID:	104307Click image for larger version  Name:	IMG_0074.JPG Views:	0 Size:	2.04 MB ID:	104306Click image for larger version  Name:	grafik.png Views:	863 Size:	281.9 KB ID:	93708
        • pipanight
          pipanight commented
          what i need do for me put m620 in this frame?
        • KaroKönig
          KaroKönig commented
          you have to make adapter plates and cut off the frame a little bit
        #19
        Are there adapter plates that allow the use of different motors?
          Unfortunately no,you have to make yourself
            If you have access to 3-D cad like solidworks there are many machine shops that will manufacture brackets directly from an emailed drawing. By designing yourself or through a friend you would be surprised as to how cheap this can be. If its flat plate, laser or water jet cutting is cheaper still.
            • feupi
              feupi commented
              Hello, do you know where I can find a drawing or the dimension to draw a mm G510 support for M620 motor from bafang ?
            #22
            Looks like Luna is finally shipping the X-1's
            Eric Hicks posted this pic on FB last night
              http://m.dengfubikes.com/index.php?s=/218.html
                Originally posted by livelrge
                I saw your post regarding frame for the Bafang M620. I've attached two screenshots, one tells you the website to buy the frame & the other is a great video on YouTube on how to build it. They're only screenshot so you'll have to type the websites in. Good luck, Bob
                Thanks but I bought a Luna X1 and the M600 motor is just right for that bike :)
