Hi,
I am new in this forum, but it really seem to be a great place to find information!
I´ve bought a used box-bike from a Swedish Company called Cargobike. I seller told me the battery was broken but otherwise everything should work.
I bought a new battery to the bike, but unfortunately the motor does not run. :-(
It has a DAPU controller, Display and DAPU rear hub motor (M123 RS) together with a PAS-sensor.
The display is working correctly, but is constantly showing 0,0 km/h independent of my speed.
I checked the PAS sensor because the magnet disc was a bit loose, but it seems to work OK. (+5V, GND supplied from Controller and signal from PAS is pulsing when pedaling , measured with volt-meter)
I checked the motor windings, which also seems to be OK, see below.
I disconnected the three feed cables from controller to the Hub motor.
- Turning wheel backward- Easy
Connected two of the motor-cables together
- Turning wheel backward - More Hard
Connected all three motor cables together
- Turning wheel backward - Harder
The motor is sensor less, means it has no Hall-sensors. It only have 3 feed lines + additional 3 small cables to the motor.
The additional 3 small cables to the motor seems to be +5V, GND and signal which I believe is a speed signal.
Measuring this speed signal (with volt meter), I could not see that it was toggeling. (constant 5V between GND to Speed signal)
I therefore believe that the problem is with the speed sensor inside the Hub Motor.
If the speed sensor does not provide any value, maybe the controller will not fire up the MOSFET¨s to the motor?
I now wonder how i could resolve this issue.
To disassemble the Hub motor seems difficult....
My current idea is to install a throttle to the controller. (It seems to have an option to do this)
Maybe with the throttle attached, the controller will not care about if there is any speed signal from the Hub motor and will fire anyway.
What do you think?
Regards
Rikard
What do you think?
Regards
Rikard
