Hi. As I have a problem powering up EggRider display on my BBSHD, I tested my battery using a light bulb as load. 56,5V on a 75W light bulb. According to my BMS the battery drew 13w. Is it ok? Or too low? Can’t figure out why it doesn’t turn on.
Load test
75W@120V gives resistance of 192Ω
13W@56.5V gives resistance of 245Ω
Resistance in bulb filaments goes up with temperature but the error here is in the low 20%'s so while not jiving completely it is in the realm of "close enough" based on the measurement techniques - for one thing, I suspect most BMS's aren't accurate...
Can't calculate current the same for AC and DC, though, right? The resistance calculation for AC is not simple constant current, it's sinusoidal, so gotta do some extra math. It's the hard way. Then you have induction effects, too, right?
Need to use accurate bulb resistance to make sense of the battery load test.
Just measure the DC resistance of the bulb with your meter, and use that value to check the battery current delivery! Keep your math and measurements in the DC realm, which is nice and simple.Last edited by JPLabs; 03-31-2020, 04:21 AM.Fabrication is fun! Build something today. Show someone. Let them help. Inspire and share. Spread the desire.
Originally posted by AZguy View PostResistance in bulb filaments goes up with temperature
Originally posted by JPLabs View PostCan't calculate current the same for AC and DC, though, right? The resistance calculation for AC is not simple constant current, it's sinusoidal, so gotta do some extra math. It's the hard way. Then you have induction effects, too, right?
That the bulb is 240V makes a lot more sense with it having about 770Ω hot (for 75W) - about 3x the much cooler 56.5V temperature resistance (~245Ω), and to me at least , that makes the numbers jive close enough that I'd bless the results!
Certainly makes a lot more sens than the calculations at 120V - funny how missing information can screw that up!
Originally posted by AZguy View PostFor purely resistive single-phase loads DCV = ACVrms... more phases it goes out the window
The resistance a bulb shows when lit will be *much* higher than when "cold"... the filaments are silly hot when lit - over a couple of thousand °K and so the resistance is similarly higher
Certainly makes a lot more sens than the calculations at 120V - funny how missing information can screw that up!Fabrication is fun! Build something today. Show someone. Let them help. Inspire and share. Spread the desire.
Hey, you guys ever seen a brake resistor burn up from the sort of voltages an ebike battery would put it through?
The 1000w brake resistor I usually use for load testing made a small popping sound few days ago,, then some smoke started coming out of the exit points for the fiberglass insulated wiring on what is an otherwise completely sealed aluminum block. My colleague said it was fine since it was still working but I'm not so sure.
I don't know the specifics of the resistor you have - if you have data throw it my way... even just measuring the resistance with a DVM would help
It's likely what they call a wirewound resistor and is basically a big heating element and made to get pretty darn hot... if they get too hot, unless it's so way over the top usually something aside from the element overheats and melts... I've even seen them get hot enough to melt the solder joints and then once everything cools down they work again although my trust in them sort of decreases =]
Does it have a fan?
It is this one, advertised as 4 ohm. No fan.
When I measure it with a multimeter it reads 4.2.
If resistance would change on a light bulb when hot, is that the case with something like a brake resistor as well?
Originally posted by paxtana View PostIt is this one, advertised as 4 ohm. No fan.
Let's say the resistance at 25°C (~298K) is R25
For the load running at 373K you'd expect the RLOAD(hot) ≈ 373 / 298 × R25C ≈ 1.25 × R25 so about a 25% increase over the room temp load
For the filament running at 2500K RBULB(hot) ≈ 2500 / 298 × R25 ≈ 8.39 × R25 so >8× over room temp
Very different beasts for sure
As for your load and it's power handling:
4Ω @ 50V would give us P = 50V2 / 4Ω ≈ 625W (~12.5A)
However at the top of a 52V (14s) pack 58.8V2 / 4Ω ≈ 864W (~14.7A)
And at the top of a 20s pack 84V2 / 4Ω ≈ 1764W (~21A)
Point being that the power going into the load goes up by the square of the voltage so you can get to the point of dumping a lot of power into it and even a 52V pack near the top would make it very hot
A couple of suggestions... the resistance seems very reasonable for a hard discharge... For 48V or 52V packs it's pushing it a bit on power but then again these are robust devices that can take some abuse although I'd mount a small fan to the unit and blow air across the little fins on the top - that will help more than you might think
Better yet (and if you're going to do 20s packs for sure) I'd put four of them in a 2p2s arrangement - this will keep the resistance at 4Ω but quadruple the power handling... for 13s/14s packs it would only get warm and with 20s it would get hot but not even close to too hot
Let me know how it goes
- 1 like
