I have an ebike which the thumb throttle stopped functioning. It worked fine one day then the next it was dead. I have a second bike, the DP C18.UART display and thumb throttle work fine when I plug it in to the spare bike. So I opened it up a little and did not see an issue with plugs so Ive been searching for a schematic so I can pin this thing out to see where the problem is. I am also wondering about using the interface to adjust programming slightly, I have a macbook and apparently you need a windows computer to get it to connect. I do have the interface cable. Any info is good info! thanks!
Bafang Ultra G510. Throttle not functioning
