Hey there, has anyone else had trouble 'lining up' the chain tensioner on a cyclone? I bolted it to the recommended place and added spacers, adjusted etc for chain alignment but it just threw the chain of at an angle? In the end - I created a heavy ziptie loop with rubber spacer (to create the correct gap) that the chain runs through - it works fine, but there is obviously going to be wear on the zip tie and I'm not sure how long it will last. Any suggestions would be appreciated - or do i just go with what I've got and be happy! I've greased tie and it doesn't seem to be wearing at speed - i guess time will tell and I will swap it out as ness. Thanks if you can help anyone!
