I've got an early version of the Luna 58.8v advanced charger that has been acting up. I'm trying to decide if it's fixable or if it's time for the bin for this unit. I have other methods of charging so I'm not completely reliant on this Luna unit to keep me moving... luckily.
Problem #1: The output voltage won't stay at a constant 58.8. I've adjusted the pot a bunch of times but after a few charges it always ends up wandering between 58.3 and 59. This has been verified on a volt meter as well as on the voltage display.
Problem #2: The charge % dip switch doesn't seem to have much effect. Sometimes it will charge to 100% and sometimes it will charge to 80% with the switch in the same place. Literally nothing has changed on the settings. I noticed that there are two other pot next to the main voltage output . Could these have something to do with it?
