I just built an ebike and when I give it throttle it shuts off? But I can turn it back on with the buttk. On the throttle then I can accelerate again, then it shuts off again . The kit is a brand new Wuxing kit I believe a 36v 500w setup but the battery I'm using is a Segway Ninebot ES2, ES3, or ES4 external battery pack is it possible that the battery doesn't have enough juice to power it because I've tested the battery with no load and with the throttle on and everything seems fine fully charged to 42.6 v or around there . Any way around this ? Can I just disconnect the BMS and bypass the LVC? Any help or suggestions is greatly appreciated thanks in advance.
New Ebike kit keeps cutting off when I give it full throttle
