Hi there, I put together a Luna BBS02 750w mid-mount kit last year and have noticed that the engine mount has loosened. Unfortunately; I don’t remember how the cranks went on, and when I removed the nut that holds it in place, I’m not able to pull the crank off. I vaguely recall just sliding the crank over the spindle, but perhaps I had to screw it on? At any rate, I’m not able to remove the crank arm. Do I need a special tool, or is there a proper technique for removing? Any suggestions on how to do this would be greatly appreciated.
Thanks, Shrekkie
Thanks, Shrekkie
