Not sure what I did her but it doesn't look good
KHS 3000 Ludicrous Controller
I've had an error 30h. It's a vague error code saying theres a communication problem between the display and the motor .
mine was a pinched wire coming off the display. For others it required replacing the harness . For still others it can indicate a bigger issue , like a damaged controller .
hopefully your issue is simple
- 1 like
- 1 like
Hey guys, here is an update on my situation. Got the new controller installed, double checked all connections ....all good. Power up the display with no errors showing. Bad news-- no PAS and no throttle. The motor does momentarily kick in but not much. I do hear the motor make some noise as if trying to engage. Need advice!!!
Much Appreciated!!!
Much Appreciated!!!
Much Appreciated!!!
