I recently upgraded my Luna Cycle Cyclone 3000w mid drive kit from 52v to 72v and when I switch the upgraded battery on nothing happens. The controller doesn't switch on and when I check the voltage at the connector (temporary terminal block) flat/no voltage.
I have swapped back and forth between the two batteries and everything works with 52v.
I also added a 72v to 12v @ 10 amp voltage regulator to run my headlight and the new battery does the same thing when connected to it as well. I switch it on and the LED headlight flashes and then goes off, swap out the 72v battery for a 52v and it works perfectly.
Any input or troubleshooting recommendations would be appreciated.
