I've replaced the chain and cassette (8 speed) about 250 or so kilometres ago.
There's no measurable wear on the chain (tried 2 different wear checkers, and measured with a ruler), however the chain has just started skipping on the 13T sprocket under heavy load.
I spend probably 85% of the time in this gear and sprocket, as it is my "cruising gear".
The cassette is a Shimano CS-HG51-8 and supposed to be made from steel.
Is it possible that the sprocket is worn enough for the chain to skip, prior to the chain wearing?
I always thought that you should be able to go through 3-4 chain replacement prior to having to replace the cassette or sprockets.
Anything I should check on the derailleur or anywhere else to get rid of the skipping, before I try to replace the cassette again?
Thank you for your help.
Disclosure: I posted this question on another ebike forum as well, however that forum seems to be broken and is displaying errors rather than posts. I'm a member and grateful reader of both that forum and the Electric Bike Forum and not one for double posting usually.
