VOILAMART Hub 1000w Help?
    Hi. I've upgraded my battery from a 48v to a 52v wich now I need a controller to match but cant find 1? I've found a 48v with 1500w instead of the original 48v 1000w. I dont know if that would still be ok as the watts now match just the volts on it are still the same. Regards Lee
    Hi Lee regarding the 48 to 52 volt battery you don't need to do anything they are basically the same the controller doesn't need to be changed and your bike will run just fine
